Help on installing running board on xe
Soninihon
Help on installing running board. I pick them off from a LE. When I took it off, the front bracket was wrap around the frame. Thinking my pathy have one, I didn't grab it as I didn't know how I'll take it off since it's wrap around the frame.
When I look under my pathy after my purchase, I notice it did not have any bracket to bolt it on. Question is: how to bolt it on or what's the right bracket?
Running I pick up
tmp_16235-DSC_0841-1322484529_zpsnrafjid
Back fits just right
tmp_27018-DSC_0840-1322484529_zpsntwaqwn
No where to mount on front
tmp_16235-DSC_0839221590747_zpsvdiztkxh.
Now I found this on ebay. It looks like it has the right bracket and it's off from Se. Could it be this bracket I'm looking for? If so what is the part number.
tmp_27018-Screenshot_2015-11-01-17-14-11
If not, then how would I go about to remove that wrap bracket?
there should be just 2 bolts per bracket that er its a 2 piece. if you need a pic i can go find my others and take a pic.
if i remember loosen the back bolt then remove the front bolt and it should just come off if you turn it. on each bracket
Edited by Kurruppt
Thank you. Now I have to wait til next weekend to go back to junk. Hopefully it'll still there.
