NovaPath Posted July 29, 2015 Share Posted July 29, 2015 I purchased some moog Sway bar links, you know the ones, the ones with the regreaseable zerk fitting. Well, I am hear to tell you, they are garbage. Less than 7k miles(and I've lubed them twice), and the passenger side is shot and clunking like mad. I'm going to pump some grease into it again to see if it will shut up for a little bit longer, but this is rediculous. It isn't just a light rattle kind of shot, either, it is the kind of shot that when turning you can feel it clunk in the floor board. Infuriating. Ok, rant over. Link to comment Share on other sites More sharing options...
Kingman Posted July 30, 2015 Share Posted July 30, 2015 Is it stupid tight to the strut and bar? If not it needs to be. That said, I have seen Moog quality go down hill lately. Link to comment Share on other sites More sharing options...
NovaPath Posted July 30, 2015 Author Share Posted July 30, 2015 Yeah, they are. You can actually feel the ball joint pop when you rock the truck back and forth with your other hand on the link... Link to comment Share on other sites More sharing options...
ferrariowner123 Posted July 30, 2015 Share Posted July 30, 2015 (edited) Yeah I had a set of those on my rig for about 3 k before they blow, replaced with Raybestos Professional, and my, oh my are they good. I will say that moog TIE rod ends are nice, feel nice, smooth movement, solved my steering wobble and are thicker than OEM. -Kyle Edited July 30, 2015 by ferrariowner123 Link to comment Share on other sites More sharing options...
