Underbelly protection; compatibility?
I ended up with an R51 at the end of a search that began with Xterras. cratching at the surface of things, the R51 shares a chassis with the Xrterra and Frontier.
Is there anything in particuluar that would keep some Xterra/Frontier plates from fitting up to the R51? Chassis, engine, trans, xfer case, fuel tank all seem the same, only the IRS stands out as a big difference.
Making my own plates is on the table, so making slight mods to a purchaned plate is certainly doable. I'm just trying to get a feel for how far and wide I can search for the best plates.
Thanks in advance!
I found that my old Subaru plate had enough metal to fit, so I started cutting.
1/4" thick 7050 alloy aluminum. It should hold the weight of the car without deflecting:
Edited by ScienceAbuse
