tdurb1327 Posted May 14, 2015 Share Posted May 14, 2015 1999.5 pathfinder 190,000 miles recent timing belt change. Needs rear bushings. Body is decent. Haven't checked it out to see if the strut tower problem is there. Guy wants $1000 he said the only thing wrong is the bushings. How hard are those to change? He says it sways when hitting bumps. Goes fine down highway. Easy fix? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Precise1 Posted May 14, 2015 Share Posted May 14, 2015 Cheap fix, might be rear sway bushings as well. Mechanically, it should run a lot longer, so check for rust and take a look at the tranny fluid (assuming AT). B Link to comment Share on other sites More sharing options...
tdurb1327 Posted May 14, 2015 Author Share Posted May 14, 2015 I have a 2000 that is almost identical to it but beat up and rusted pretty good. I'm thinking of swapping my AC lift to it. Then use it for parts. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
NovaPath Posted May 14, 2015 Share Posted May 14, 2015 For a grand seems hard to go wrong, depending on what registering fees etc are where you live. Link to comment Share on other sites More sharing options...
