Camshaft sensor
ebayfish
Its on the back of the head. Last time I changed one, I had to lay over the top of the engine and was able to get my hands back there to remove the 10mm bolt that holds it in. The biggest pain is the locking connector. A small flat screwdriver will help push the green lock part in. You can also wait to disconnect it after you unbolt it and slide it out of the head.
