ebayfish Posted March 14, 2015 Share Posted March 14, 2015 Asking for a friend, where is the passanger side Camshaft Sensor located on a '05 4.0 2wd. Any tricks for removal & replace? Thanks. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted March 14, 2015 Share Posted March 14, 2015 Its on the back of the head. Last time I changed one, I had to lay over the top of the engine and was able to get my hands back there to remove the 10mm bolt that holds it in. The biggest pain is the locking connector. A small flat screwdriver will help push the green lock part in. You can also wait to disconnect it after you unbolt it and slide it out of the head. Link to comment Share on other sites More sharing options...
