Fuel level sensor, troubleshooting and cleaning?
Rebelord
I have the procedure to check it in the FSM. However if its out if specs. Has anyone had any luck adjusting or cleaning it up to be in specs? Or will I have to replace the whole pump and unit as one?
I am referring to my new 2004 LE. When it showed empty and light on. It only took 16 gals. Then after 25 miles on full. Says I used a 1/4 tank. Put gas and barely took over 1gal. So its way off.
TIA
Sent from my Moto X
