Rear hatch linkage problem
Guest Jose Garcia
Guest Jose Garcia
Hi 88pathoffroad, my '94 pathy back door, not the side door, doesn't open with the key. I have to use the electrical switch. I removed the plastic panel and discovered that the little rod that moves the machanism to open either the glass window or the whole door is disconected from the thing which is turned by the key to open the door. I know there is missing something that holds the little rod and that other part I don't know what it is. I was wondering if the manual you have has information about this situation. I thank you for your willingness of helping.
