Limited slip clunk when turning wheel opposite direction
stabworthy
This happened in my F350, I changed the fluid with a synthetic blend & LSD additive. I also change all the u-joints on the driveshaft for good measure(in case the noise was in the driveshaft). One of the two things fixed it.
Well that rules out u joints. I'd start with fluid & see what that does. Its probably due regardless. What does it do if you dpin it at the yoke?
Edited by ebayfish
