Manual hub bolt stud size
So I run 35s with manual hubs. Also locked up front. Something I noticed recently is that the studs you bolt the hub to have broke. Looking for the part number or thread sizing to replace them with.
Like the bolts that hold the locker on? And if it is those i think you could contact the company and they could Get you them
Sent from my LG-LS840 using Tapatalk
The bolts/studs that used to attach the drive flanges that were removed to mount the manual locking wheel hubs? The thread is M8x1.25, and I'm pretty sure 30mm is the length but you need to verify that by pulling one.
