88pathoffroad Posted February 6, 2005 Share Posted February 6, 2005 I have a Nissan FSM for 1988 Pathfinders and Hardbody pickups that I can offer some factory information from if anyone has a specific question or need. Just let me know and I'll see what I can do for you. I just wanted to make it known and let everyone know that the offer stands open for anyone. Also, PLEASE, no requests for mundane things like "what spark plugs should I use" or "what size windshield wiper do I need", those things should be easily found by either searching these forums or asking/calling a local parts store. Off-topic requests will be deleted at will. Thank you. -88 Link to comment Share on other sites More sharing options...
Guest tonkatoy Posted February 23, 2005 Share Posted February 23, 2005 Need to learn how to reprogram the keyless remote I bnought off EBAY. I replaced the battery and tried holdong the button upder the front drivers seat, but still no luck. if they have it listed step by step that would help. 2. Could you please tell me what the box under my front passenger seat is, it has a adjustment dial on it Thanks Tonkatoy( Bill) Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 23, 2005 Author Share Posted February 23, 2005 87-89 Pathfinders don't come with keyless entry or alarm. Next! Link to comment Share on other sites More sharing options...
Guest mightymax97 Posted May 19, 2005 Share Posted May 19, 2005 Could you tell me what the color codes are for the male and female connectors for the fuel pump and sender. The wires were pulled out of both and now I need to hard wire. Please help cause I'm with out and wheels. thanks Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 21, 2005 Author Share Posted May 21, 2005 I looked through my FSM again...there should be a wire that's white with blue stripe, and a black wire. That'd be your main 12VDC power wire and ground wire. The sending unit wire is a mystery so far, they don't list it in the generic wiring diagrams. How many wires have you got to reconnect? List the colors, etc, please. Link to comment Share on other sites More sharing options...
MidTex01GT Posted June 1, 2005 Share Posted June 1, 2005 One terminal starter or two? Looking at getting a replacement at my local Autozone and it lists 2 parts for my year/motor. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 15, 2006 Author Share Posted May 15, 2006 There's one terminal for main power from the battery and one for the starter solenoid wire. Link to comment Share on other sites More sharing options...
Guest cutty513 Posted August 2, 2006 Share Posted August 2, 2006 (edited) Is there a relay that would connect the turn signals and running lights and if so, where? 95 XE V6 Edited August 2, 2006 by cutty513 Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 3, 2006 Author Share Posted August 3, 2006 No, but they both run through the headlight switch. Link to comment Share on other sites More sharing options...
