lift level instal?
joshboy22
I got a 2" lift level kit from one the npora members (can't remember his name right now) and I seen that a few other members have the same lifts. I was just wondering if there is a step by step guide? I have a Haynes manual and it looks like it's easy as dropping the rear and popping them in. And just drop the struts and put the spacers in place. Any info or personal experience would be a big help.
Thanks
it helps if you've got friends. removing and re-installing struts is just no fun. follow the haynes instructions for removing struts and rear springs.
as for the rear I had a friend with a forklift help as I didn't have a tall enough jack to lift the vehicle and then lower the rear axle. just watch that rear brake line as you are lowering the rear axle. it gets too short too quick.
I'm sure you'll figure it out, just play safe and use wheel chocks and axle stands.
