ECU code 51. Injector circuit. Help
mikestewart395
That comes down to harness connector or injector. I'd start by checking the passenger side wher it is easy, you have a 50% chance of getting lucky. Check the wiring harness visually for any possible damage, check each injector connector for corrosion/integrity and check the pins on the injector with a multimeter for resistance, It should be 10-14 ohms.
Check out Diagnostic procedure #35 on page 108 of the FSM, EC-108. It has all the harness test specs as well.
I'll add, when testing the injectors for resistance, make sure the terminals on the injectors are good and clean before you rule them out as faulty!!! I "had to" replace two injectors, well, once I had them out, and scraped the terminals with a flat screwdriver, magically they showed the proper resistance!
  • 3 months later...
The day after I replaced the injector I took it to work, it went into limp mode on the first stretch. At lunch I drove it and I let it rev up tp 5k rpm. I am thinking the ECM needed a restart or something. Then I ran out of gas, lol. Now it is still sitting in timeout, I should be done repairing the fuel sending unit tonight. Thank you JB Weld!!!!! That stuff is awesome. But after I got it back to work I took it in the woods and turned it loose and it was running good. Not confirmed 100% yet, but it was doing good at the time.
