WD21 ECU Swap
tdauria
Do you think it can be tuned enough to pass CA smog test? Took it off road today and at higher elevations 3000 - 6000 ft it was feeling a bit tired even with the new headers / exhaust.... needs moar air!
Edited by enkrypt3d
Oh I'm sure you could get it to pass, but it might be trial and error. Best thing to do is make two chips. One chip containing factory tune with n60 maf support alone and then a second performance chip with n60 maf support.
plug in the factory chip for the test and then crack open the ecu case and put in the performance tune chip when you get home :P
N60 maf/tune and cams are the way I'm going next. Should be the best bang for the buck power wise for my goals
