Specialty Tools and Vendors
MrEviLDeD
Hey everyone,
I was searching around here on the forums for a thread that dealt with special tools required to work on Nissan, and of course Pathfinders. I by no means have any kind of list built up yet but got to thinking that maybe a thread that gave links and or information on how to customize tools to do the job might benefit others. If not then the thread will die or can be killed.
I will start this list with the Wheel Bearing Lock Ring tool. After lots of searching and consideration of the modification of an existing axle spindle nut or lock ring tool I went to task to locate something more appropriate.
Please note that this is a limited sale and while I have purchased one of these I lay no claim to the merchant in anyway so you need to use your own personal judgement when deciding if you will buy one.. There are 8 left. I am looking for a more common place for the tool but for right now here it is:
Wheel Bearing Lock Ring Tool/Axle Spindle nut tool
As I locate sources for the varying specialty tools used to work on the Pathfinder I will list those links here. I also encourage others if you find a place for a special tool please post a link here for others to find too..
Cheers everyone.
