level9 Posted March 4, 2014 Share Posted March 4, 2014 I figured I would share how I removed my exhaust manifold studs without breaking them since this appears to be a big problem on these WD21s. This was on a '90 with original, very nicely rust rotted manifolds and studs. Luckily, I had a lot of prior experience on the pathy destroying bolts with pb blaster failures, heat/shrink failures, breaker bar disasters and snapped bolt heads flying from my impact wrench.. and I wasn't looking for a repeat in this situation. Here's what I did: - soaked with Aerokroil every other day (basically whenever I remembered) for a few weeks. Aerokroil is like PB Blaster, except it actually works. It will cost you 3x as much as a can of PB too but worth it. - used a cordless impact wrench (not my tear-your-arm-off pneumatic) to SHOCK the studs loose. 5 or so gentle, quick pulls on the trigger and verify it's loose. If not loose, continued soaking. All of the studs came out with the nuts except 3 and those nuts came off. - remaining studs I soaked for another week or so with Aerokroil. During that time I would check the studs with a large pair of vice grips - applying FAIR hand pressure to see if it was loose. If not, continued soaking. - when the studs came loose, switched to a small pair of needle nose vice grips and gripped the stud length wise and they came right out! If I had to do it again, I would probably NOT soak the rust-welded nuts. Instead, use them for driving the stud with the impact while soaking the stud area between the manifold and the block. Might have saved a little time. good luck! Link to comment Share on other sites More sharing options...
