Pulled crank pulleys off damper, help me line up marks please!
93pathyfiend
Ok so pretty self explainatory... Doing rebuild and so far so good, of course I'm reassembling and notice that I'm an idiot and unbolted my pulleys from the crank damper without marking them. So my question is when the motor is at TDC, based on crank and cams, which of the 7 marks on the pulley should line up with the timing cover? The only reference I have is the Haynes and it only shows the ka24 marks in detail, are they the same? Any help would be great,I miss my pathy something fierce
Sent from my iPad using Tapatalk
I think each mark is 5-degrees apart, so if the leftmost mark is 0 degrees (Top Dead Center), each additional mark is 5-degrees BTDC (0-5-10-15-20-25-30)
Good luck!
Edited by peejay
