Starter Problem? WD-40 helps!
Guest Fuchfaccio
Guest Fuchfaccio
My 88 Pathfinder won't start, but only sometimes, usually when it's real cold. For example, today was -20celsius or so and I turn the key and I hear a click under the hood but it won't turn over. If I turn the key back and forth (off to start to off to start and so on) it will eventually start at least so far it has. I'm really affrad of it leaving me stranded though, not that a Nissan would do that, I've had this Pathy for2 years and has never left me stuck. Do I need a new starter?/solonoid? If it doesn't start right away I spray WD-40 on the solonoid nuts and wait 5 minutes then she'll start right up. Maybe the contacts just need to be cleaned? The starter works when I put power to it, and the click I hear is (I beleive) the solonoid. whats the best, and easiest way to get the starter out so I can clean it or replace it? It's certainly buried in there. Thanks, Mike
Is WD-40 duct-tape in a can or what? :P
Usually the clicking noise means its a low/almost dead battery. Take it to a parts place and have them check the voltage. Have you replaced the battery in the 2 years youve owned the truck? If not, with the 20 degrees C, it might be time. Cold kills batteries. If it was the solenoid or starter it wouldnt start at all... clicking or intermittant usualy means low voltage.
Pat
