Trimming to clear tires
dustinp
First off I have a 4" Subframe Drop on my 2001 pathfinder, no AC coils. I have stock Titan Wheels with 295/70/R18 Tires, which are about 34.75" tall. I finally got the my steering fixed and rubbed right away. This is how Im running it right now until I can do some serious trimming. Also I am using 2" wheel spacers to clear the struts and to also fit the stock Titan wheel on my pathy.
Front Driver Side Bumper
Front Drivers side Rear, had to grind quite a bit of metal off the truck to clear
Rear
Rear
Front Passanger Side Bumper, I cut a slit so I could push the shroud forward
With all the shrouds I just drilled new wholes and shoved them as far as I could. Im sure Ill lose them eventually but it seems good for now.
After an alignment and tire balance, the rig seems to drive pretty damn nice, even with the two inch wheel spacers, now much shake at all and only a tiny growl. Im very happy with how it turned out, and sorry I didnt post this in the tire section, couldnt find it.
Looks good, the trimming seems pretty tame, similar to what I recently did. I still think the 18s and tires are hotness
Edited by patqx4
