torque specs struts to camber plates and strut to spindles?
Hi,
I have a 98 pathy and have ordered the Old Man EMU kit from Rock Road.
I need the torque specs particularly the strut(s) to camber plates and at the strut to spindles.
Anybody know what they are?
Appreciate your help!
Matt
haynes manual sais... strut-to-steering knuckle bolts 111-122 in-lbs
strut upper mounting nuts 29-40 in-lbs
strut piston rod nut (1998 and later) 43-58 in-lbs
those are all the fasteners required to install a strut (not sure what you are describing as "strut to spindles"
anyway good luck, have fun and check everything twice!
