qatcool Posted May 5, 2013 Share Posted May 5, 2013 Hi all, I have this concern of delayed shifting. this only happens in the afternoon when oil is already hot. i went to Nissan and told me that the transmission is already finish due to burn oil and need to replace the transmission. 1 mechanic told me that this is due to TPS throttle position sensor. I am planning to change the transmission oil. any advice. is my transmission already gone. Link to comment Share on other sites More sharing options...
CNAM Posted May 12, 2013 Share Posted May 12, 2013 Transmission is probably fine. I changed the TPS on mine and resolved this issue. Mine was also neglecting to shift and would bounce off the rev limmiter when taking off from a stand still (first gear). I changed the TPS, Mass Airflow Sensor and fully took apart the throttle body and cleaned it and cleaned the K&N air filter. This seemed to do it for me. I am now dealing with an ignioion coil issue. It helps if you can get the codes from the ECU. Link to comment Share on other sites More sharing options...
