The_Magicians_Eye Posted May 2, 2013 Share Posted May 2, 2013 2 Link to comment Share on other sites More sharing options...
andreus009 Posted May 2, 2013 Share Posted May 2, 2013 Nice Job 1 Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted May 2, 2013 Author Share Posted May 2, 2013 Thank you Link to comment Share on other sites More sharing options...
PHR Posted May 4, 2013 Share Posted May 4, 2013 Looked at them all. Very informative. Thank you. Philippe. 1 Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted May 4, 2013 Author Share Posted May 4, 2013 Thank you and you're welcome. Link to comment Share on other sites More sharing options...
jj big shoe Posted May 4, 2013 Share Posted May 4, 2013 That is likely the correct way to remove it, but I didn't do any of that. Just remove the door panel and the horizontal trim piece at the bottom of the window (where your arm would rest when the window is down). Pop the upper portion of the seal off the door frame then you should be able to work the rest of the old seal out of the track. Shoot some silicone spray on the tracks and on the new seal then slide them back in. Pay attention as you go so the window rides where its supposed to then pop the rest of it in around the corners and you should be good. I removed the seals from a Hardbody in the JY then installed them in my truck in this manner. Since then I've removed and installed them twice for paint prep without taking the windows or tracks out of the doors so altogether I've done it six times without a problem. Good luck. 1 Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted May 4, 2013 Author Share Posted May 4, 2013 There is always more than one way to skin a cat. Link to comment Share on other sites More sharing options...
