dakotab93 Posted December 29, 2012 Share Posted December 29, 2012 Anyone installed a aftermarket remote start in there pathy? Link to comment Share on other sites More sharing options...
linkinpark Posted January 2, 2013 Share Posted January 2, 2013 I have. I have a 1998 Manual 4x4 Link to comment Share on other sites More sharing options...
dakotab93 Posted January 3, 2013 Author Share Posted January 3, 2013 I have. I have a 1998 Manual 4x4 how hard was it to do, and by chance do you know exactly what wires you had to tie into, i have a 1997 4x4 so it should be the same. Link to comment Share on other sites More sharing options...
93xe Posted January 3, 2013 Share Posted January 3, 2013 if you have any 12v wiring experience at all, its not too difficult. 99% of the wires are under the driver side dash at the ignition harness, and at the secu (security control unit) to the left of the steering column. Tach signal is underhood as well as hoodpin. Link to comment Share on other sites More sharing options...
dakotab93 Posted January 4, 2013 Author Share Posted January 4, 2013 I have some experience in it. I figured there was only 4 or five ignition wire that are need, do you know if its possible to tap into the harness behind the cluster for the tac? Any possible way you could post a picture? Link to comment Share on other sites More sharing options...
linkinpark Posted January 4, 2013 Share Posted January 4, 2013 http://www.the12volt.com/installbay/alarmdetail/1640.html That will give you pretty much everything you need. I tied into the tach from the gauge cluster. Only have two wires going into the engine bay. Hood pin and alarm siren. Not pictures. Don't feel like tearing it all apart. Link to comment Share on other sites More sharing options...
dakotab93 Posted January 4, 2013 Author Share Posted January 4, 2013 Thank you so much that helped a lot Link to comment Share on other sites More sharing options...
dakotab93 Posted January 9, 2013 Author Share Posted January 9, 2013 Is there any bypass modules needed? Link to comment Share on other sites More sharing options...
linkinpark Posted January 9, 2013 Share Posted January 9, 2013 No there isn't. I do not think a chipped key was even an option in our rigs. Link to comment Share on other sites More sharing options...
dakotab93 Posted January 9, 2013 Author Share Posted January 9, 2013 What about any relays? Link to comment Share on other sites More sharing options...
linkinpark Posted January 15, 2013 Share Posted January 15, 2013 Hope you got it all figured out but I never had to use any extra relays. But it really would depend on the remote start system. Link to comment Share on other sites More sharing options...
shoesandsocks Posted January 16, 2013 Share Posted January 16, 2013 01 and newers have chipped keys i know Link to comment Share on other sites More sharing options...
dakotab93 Posted January 16, 2013 Author Share Posted January 16, 2013 No I have not gotten I all figured out yet but I am working on it, mine is a 97 so no chiped key Link to comment Share on other sites More sharing options...
linkinpark Posted January 17, 2013 Share Posted January 17, 2013 What are you having problems with? Link to comment Share on other sites More sharing options...
dakotab93 Posted January 19, 2013 Author Share Posted January 19, 2013 I think I'm haveing a problem with the tach signal because the module only clicks just no start Link to comment Share on other sites More sharing options...
linkinpark Posted January 19, 2013 Share Posted January 19, 2013 What is the model of system you are using? Link to comment Share on other sites More sharing options...
dakotab93 Posted January 20, 2013 Author Share Posted January 20, 2013 It is an audiovox aps 901c. It isn't learning the tach rate. Link to comment Share on other sites More sharing options...
