Headlight Harness
rocky2
I thought I would pass this on. It's inexpensive and really improved the headlights. I got this idea off a jeep web-site and put it in my boys Cherokee with IPF Fatboy bulbs and Hella lenses. I know, pretty spendy for this set-up. It really worked out well for him.
But on the pathy I just did the harness and some Silverstar bulbs and it worked out pretty good. I added some wire loom sheathing, shrink wrap,some extra zip-ties and routed it carefully and thought I would post. As we all know, the relay is doing all the work with the power going from battery to relay and then to bulb. Means brighter bulb.
http://www.coolbulbs...ing_harness.asp
http://www.amazon.co...star ultra 9004
About $70 and you get alot of improvement out of your headlights.
Edited by rocky2
I thought this was unnecessary on R50s since the headlights are relayed already? Or is the stock wiring still marginal, and an upgraded harness would still be beneficial? Headlight harnesses are a common upgrade for WD21s since those headlights are not relayed.
Edited by Towncivilian
