RPM gauge not working
Dg123
Hey everyone first post but I look on here all the time.
This is the only thing I haven't see.
My rpm gauge it will get to about 1000 and just drop back down I dont know anything about that so all the help will be amazing.
Thanks for all the information I get from this site and glad I found it.
Step one is to gently remove the instrument cluster and make sure the brass screws that double as contact points are tight. That seems to solve some problems (I've had a dead Tach come back to life once it was swapped to another vehicle, and then there was te speedo...)
It's usually the contact points in the cluster or in the connector to the cluster. You can try pulling the cluster and tightening the screws like Precise1 said. The other option to try is to go and see if the connection to the distributor is good. There is a little wire that goes to the distributor to send the tachometer signal. Sometimes that gets really loose and you lose good signal to the tachometer.
