Guest wickedvision Posted December 16, 2004 Share Posted December 16, 2004 Just a Little FYI for anyone looking into buying the Calmini steering upgrade. There is a difference between the 92 and 92.5 pathfinders . My Pathfinder was made in 3/92 and calmini had me call the dealer to find out if it was a 92 or 92.5 . The dealer told me it was a 92 . turns out that it was a 92.5 and my $60 I paid for 3 day air was a complete waist. Any way got the right part a week later and it will be going in tonight . Link to comment Share on other sites More sharing options...
MaritimeMan Posted December 16, 2004 Share Posted December 16, 2004 are you talkin about the pitman arm hole? Ironicaly enough, I had the same problem with my 91. Great service though, they shipped me the new one right away, and just said mail the wrong one back asap and gave me return postage. Here's the side by side of my old pitman arm, and new (wrong) Link to comment Share on other sites More sharing options...
Guest wickedvision Posted December 20, 2004 Share Posted December 20, 2004 Yeah it was the pitman arm hole .the pre 92.5 is smaller by quite a bit. I just wanted to help other people get the right part the first time . anyway I just installed it saturday and it was a pretty straight forward installation and the allignment center had no problems with the alignment. It should have come with beefier outer tie rod ends though . It seems that that would now be a weak link. but it's a very trick setup none the less. Link to comment Share on other sites More sharing options...
MatterHorn Posted December 22, 2004 Share Posted December 22, 2004 isn't that the beauty of it though? now you have an indestructable center link, pitman, and idler arms, which are FAR more expensive to replace than a couple of bent TRE's ... and the TRE's are easier to replace as well ... Link to comment Share on other sites More sharing options...
MaritimeMan Posted December 22, 2004 Share Posted December 22, 2004 Yah, I'd rather have a cheep, 20 dollar item as my weak link, rather than the whatever it costs for the other parts. Peace of mind in the other parts is what the kit is all about. your complaint is the main reason is why I love the Calmini kit. It creates a solid system, where the weakest part is the place where one, yes it is most likely to fail, but on the other hand, it is the easiest to replace. Makes sense in my mind. M.M. Link to comment Share on other sites More sharing options...
Guest wickedvision Posted December 29, 2004 Share Posted December 29, 2004 Has anyone with the steering upgrade also added a steering damper? I am pretty sure that there should not be any clearance issues but I thought I would check with you guys first . I was thinking of getting the rancho unit . Thanks Link to comment Share on other sites More sharing options...
MaritimeMan Posted December 30, 2004 Share Posted December 30, 2004 Oh yeah, the rancho kit doesn't fit. I'm gonna have to modify the drop bracket that comes down form the idler arm out away from the center link, then make a new bracket to attatch to the centerlink. Nothin too hard, just time consuming. Link to comment Share on other sites More sharing options...
