stalker Posted July 10, 2012 Share Posted July 10, 2012 lots of different options out there and i am wondering what works for you... post up pictures if you got them Link to comment Share on other sites More sharing options...
GrandpaX Posted July 11, 2012 Share Posted July 11, 2012 (edited) Leaf Spring = High steer Coil spring = normal steering works fine. Full Hydro = heims for sure Heim vs One Ton.... I have used both. Went away from Heim and never looked back. The one tons have held up perfectly on 38's and hydro assist for 4 years now. Heim joints were a yearly change out. Edited July 11, 2012 by GrandpaX Link to comment Share on other sites More sharing options...
Mr.510 Posted July 12, 2012 Share Posted July 12, 2012 Heims don't live nearly as long as TREs, even if you run joints with grease zerks and Seals It washers to keep the crud out. Also, I've read all over the web that heim joints are illegal on the street in a whole bunch of states. That said, I've never checked so it could be more internet BS. Link to comment Share on other sites More sharing options...
Tungsten Posted July 12, 2012 Share Posted July 12, 2012 Tie Rod Ends all the way. Screw that Heim crap. Link to comment Share on other sites More sharing options...
stalker Posted July 13, 2012 Author Share Posted July 13, 2012 Well I guess I should have done some more research if everything you guys have experienced and saying is true about heims...lol I am going with 7/8 Heims on crossover histeer...but I know I will Definenitly be putting them to the test....I'll let u know how they hold up. Link to comment Share on other sites More sharing options...
GrandpaX Posted July 13, 2012 Share Posted July 13, 2012 (edited) The heims are only half the problem.. the bolts go straight through the knuckle without the taper... thus tend to get loose. They should work fine... just keep you eyes on them. BC Broncos makes these little gems... they tend to fix the loosening problem. However your arms are probably drilled for a bolt already. http://www.bcbroncos...inglinkage.html Edited July 13, 2012 by GrandpaX Link to comment Share on other sites More sharing options...
stalker Posted July 13, 2012 Author Share Posted July 13, 2012 yea i am pretty sure my arms are drilled...i think they come that way Link to comment Share on other sites More sharing options...
