Is my 5th link...
... the reason for my pull? I was reading that the earlier models use a Panhard drop down bracket to level out the 5th control arm. I looked and mine is at an angle like theirs were before the bracket install. Anyone done this? Know where to get one?
The panhard rod should be parallel to the axle. If it's on an angle, then it has moved the axle laterally, which can change the angle of the axle to the body.
Fancier setups use Watts linkages instead; they don't have this problem to the same extent.
What's a Watts linkage???
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
