AC Lift.... again.
TShep704
you can but its recommended that you just replace the struts when its all out, plus if you got alot of miles and they are original you could run into problems down the road.
and the stock shocks will work but you'll have very little suspension travel. if you going to do it, get it all done at once so you dont have to mess with it later...
the AC coils replace the "factory coil springs", so i am kind of confused about why you said suspension..
yep, just a big differnce in 750 and 350 dollars... ha ill probably just save til i can get the entire kit... i can run 31s stock, right?
You can run the 31's stock with cutting away at the plastic wheel well liners. Shoot, I've had to cut mine away with the AC lift.
