02silverpathy Posted November 29, 2004 Share Posted November 29, 2004 Hi all, bought all those things to make my 98 pathy a cold air hog... crawled under, removed, pulled out, ...and learned something! That big air box that is removed to make the new intake happen, holds a near critical and ingenious piece!!! ********start paying attention here!! ************* on this big*** box it has what appears to be a goosneck that reaches back up to the inner fender that actually is the stock intakes end...this "goosneck" or arm shaped piece is pop-riveted on...drill it out, now crawl back under the truck with it and hold it up to your oem air box and hole in the subframe....TA DA, its near perfect! It will require some shaving to be the correct length for the under fog light location, but with a rubber coupler it will fit well and be flexible enough to put the stock shielding back up. It also still has the bung for the stock maf sensor!! QUESTION.....all you guys that already have this or some sort working...how are you re-installing that plastic that you cut out? O---------r are you using something else to cover up for snow and mud? thatnks, enjoy!! Link to comment Share on other sites More sharing options...
DJ Dank Posted November 30, 2004 Share Posted November 30, 2004 I just used a dremel tool to cut out part of my bumper to create more air into the intake. Link to comment Share on other sites More sharing options...
big_johnson Posted December 1, 2004 Share Posted December 1, 2004 I used mesh like DJ, but with a circular hole cut out that hooks to a flex pipe which runs to the underhood airbox. I have a picture and a description of it somewhere in my cardomain page, the link in my sig Link to comment Share on other sites More sharing options...
JB3829 Posted December 9, 2004 Share Posted December 9, 2004 I cut a hole thru the plastic under the parking light, then one thru the air box and shoved an adapter piece from my leaf blower thru both holes(with screen attached at the end). I then attached a piece of gutter guard mesh in the opening at the front of the pipe. Looks NICE! If it gets too muddy, I can cover it up with the top from a spray paint can. I'll see if can get a picture of it. Link to comment Share on other sites More sharing options...
