Guest huntony Posted November 28, 2004 Share Posted November 28, 2004 Where is the MAP sensor located on an 87' Utility E? Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 29, 2004 Share Posted November 29, 2004 There is no MAP sensor. That's the acronym for a manifold absolute pressure sensor, correct? You looking for the mass airflow sensor or the exhaust gas recirculation valve instead? Link to comment Share on other sites More sharing options...
Guest huntony Posted November 29, 2004 Share Posted November 29, 2004 Hmm, your correct on what I was refering to as MAP. Where is the other sensors you were talking about? Also, have you ever heard of the dual injectors going out on these rigs? I have the Z24 engine which has dual spark plugs per cylinder. It started cough like it wasnt getting fuel and now want start. I am having trouble determining what is wrong with it. It is getting spark, I checked that already. Any suggestions? Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 29, 2004 Share Posted November 29, 2004 Checked your fuel pressure? Fuel filter replaced recently or old? The injectors don't usually just die, AFAIK. The mass airflow sensor is integrated in the TBI unit. The EGR valve wouldn't cause a no-start condition. Link to comment Share on other sites More sharing options...
