gearing
nick1716
On the XE's and LE's, the gearing is 4.363:1. The SE's had 4.636's in the axles because of the larger tires that came stock. The latter would be good for 31's, but it wouldn't be worth the hassle of regearing for such a small tire change. Now if you eventually got a big L&P lift and threw 33's on there, you'd want to regear, but with just 31's you should be OK with the 4.363's ;)
