HELP with NTB99-004B!
savagea
This TSB says the bolts that I need to connect to the 2 threaded holes on the RH cylinder head are "08146-8121G". I received these today after a week of waiting and they are clearly too small. They are the same size as the small bolts on the other end of the harness on the intake manifold. This is a 1999.5 Pathfinder. Is the TSB wrong?? I'm stuck. Has anyone done this fix and can shed some light??
