1994SEV6 Posted November 24, 2011 Share Posted November 24, 2011 So my Hood release doesn't work anymore. For the past few days I've had to pull of two or three times for it to work. Now it doesn't work at all. I'm pretty sure it just popped out of a fitting or came loose somehow. I don't think it rusted. At least I hope not. So how do I pop my Hood without this? I'm clueless. I took off my drivers side blinker thing to try to reach up there, bit that was useless. Link to comment Share on other sites More sharing options...
Trogdor636 Posted November 24, 2011 Share Posted November 24, 2011 So my Hood release doesn't work anymore. For the past few days I've had to pull of two or three times for it to work. Now it doesn't work at all. I'm pretty sure it just popped out of a fitting or came loose somehow. I don't think it rusted. At least I hope not. So how do I pop my Hood without this? I'm clueless. I took off my drivers side blinker thing to try to reach up there, bit that was useless. First, check the cable in the cab. Is it loose/broke there? If so, just grab it with some vice grips and yank it that way. If its broke at the latch itself in the front, the best you can do is try to get something in there to unlatch it through the grille. Link to comment Share on other sites More sharing options...
1994SEV6 Posted November 24, 2011 Author Share Posted November 24, 2011 First, check the cable in the cab. Is it loose/broke there? If so, just grab it with some vice grips and yank it that way. If its broke at the latch itself in the front, the best you can do is try to get something in there to unlatch it through the grille. Yeah. I'm pretty sure it came loose at the latch. Well, somewhere along the way. I unscrewed the bracket that the hood release was on and the cable had some slack. I pulled it out about 6 inches..so something definitely came unhook. Ugh. I guess I just need to invent some tool to go through the grille and up and pull down. Link to comment Share on other sites More sharing options...
1994SEV6 Posted November 24, 2011 Author Share Posted November 24, 2011 so...how do I open the hood? If I reach up, I just get tab that you lift to open the hood after it's already popped. I tried to lift this tab when I had my grille off, it doesn't do anything by itself. Is there like a hidden hook somewhere? Link to comment Share on other sites More sharing options...
Trogdor636 Posted November 25, 2011 Share Posted November 25, 2011 so...how do I open the hood? If I reach up, I just get tab that you lift to open the hood after it's already popped. I tried to lift this tab when I had my grille off, it doesn't do anything by itself. Is there like a hidden hook somewhere? That tab is basically a safety feature, so you dont hit the hood release in the car and your hood flies up. Check this thread for a picture of the hood latch, the cable from your cab runs to this, and the initial hood release from in the car pops this open. I'll send a better pic later, its raining here right now. http://www.nissanpathfinders.net/forum/index.php?showtopic=17796&st=0&p=291060&hl=+hood%20+latch&fromsearch=1entry291060 1 Link to comment Share on other sites More sharing options...
1994SEV6 Posted November 25, 2011 Author Share Posted November 25, 2011 ouuu thanks. pretty helpful. Link to comment Share on other sites More sharing options...
Mr.510 Posted November 25, 2011 Share Posted November 25, 2011 With most Nissan hood latches you can stick a long screwdriver through the grille and pry the ear the cable end attaches to sideways to release the hood. I don't recall if this works on a Pathy and the weather is like the inside of a dishwasher or I'd go look at one of mine. Look through the grille with a flashlight, preferably when it's dark outside or in your garage so you can better see the latch and where the release is located. Link to comment Share on other sites More sharing options...
