remote for 90
Guest pathfinder54
Guest pathfinder54
need to know about the remotes the guy i am buying my pathy off of say it does
not have the box under the driver set but their is one under pass seat what i do not under stand is it has the security system from the factory how do i activate and deactivate alarm :help:
Not sure of your actual question but there should be a switch on the console to turn the alarm system on/off. Remotes are easy to come by (watch ebay) and simple to program. Even without one, you can open the vehicle with the key and just listen to the alarm for a couple moments while you get the key into the ignition and turn it.
