makie Posted May 20, 2011 Share Posted May 20, 2011 Hi folks If you've noticed my other recent thread you know I have a coolant leak from somewhere under the intake manifold. I just received my gasket set and was getting ready to start working when I noticed the gaskets they sent me are for a VG33E (I have a '95, VG30E). I know there are some similarities between engines so any chance the intake, plenum and throttle body gaskets are the same for each? thanks Link to comment Share on other sites More sharing options...
MY1PATH Posted May 20, 2011 Share Posted May 20, 2011 I can't remember if the 3.3 has lager ports but all the bolts are in the same place. You should be fine. Link to comment Share on other sites More sharing options...
makie Posted May 21, 2011 Author Share Posted May 21, 2011 Thanks. From what I could I find they're the same part so I decided to just do it and hope for the best. Tear down is finished, I haven't held the new and old gaskets together to know for sure but they do all look the same. Link to comment Share on other sites More sharing options...
makie Posted May 22, 2011 Author Share Posted May 22, 2011 for the record... intake and plenum gaskets are the same, throttle body is not. Link to comment Share on other sites More sharing options...
