Passenger door lock doesn't work.
Pathy415
I've owned the car for about a year and never got around to fixing the drivers side passenger door lock. All the other locks work fine but when I try to lock the passenger door from the inside using the master switch or arming the car using the remote it won't activate(lock). Does anyone know what could be the problem other than the actuator?
I'm new to this forum and have owned the truck for almost a year. Any help is appreciated!
i had this same problem with a Blazer i use to own.
Tear the door panel off and make sure the locking mechanism isnt broken before replacing the actuator. I had the plastic lock button that hooks on the actuator break on me before.
If everything on the door panel looks ok, replacing the actuator should solve the problem.
