87mudfinder Posted November 5, 2004 Share Posted November 5, 2004 I need help in locating this valve? :X Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 5, 2004 Share Posted November 5, 2004 There's a smallish (1") hose coming off the valve cover on the passenger's side. It's the only one connected to the valve cover itself. At the other end of the hose is the PCV valve. Link to comment Share on other sites More sharing options...
87mudfinder Posted November 5, 2004 Author Share Posted November 5, 2004 pmd you dude gotta get address's swapped stat so i can send you some cash... I need the parts asap so i can start the insane in the membrane susp lift & body lift and paint certain parts up....... Link to comment Share on other sites More sharing options...
87mudfinder Posted November 27, 2004 Author Share Posted November 27, 2004 i still cannot find this valve on my engine :oops: what gives manual doesn't help either can someone show me a pciture of this valve location with a dig cam shot? sly Link to comment Share on other sites More sharing options...
Guest evugrapeape Posted December 14, 2004 Share Posted December 14, 2004 If you are looking at the engine, on the left hand side valve cover there is a 1" black hose hooked to it by the firewall. Follow that hose up under your TBI to where it goes into the intake manifold. Where it connects to the manifold is your pcv valve. I moved mine. I think i used a 3/8 brass barb fitting in place of the pcv valve. Took the other end the 1" hose and cut it off just above where it flares out to go into the valve cover, and i used a pcv valve from a 92 cavalier 3.1. The body of the pcv valve slids right into the valve cover and you use the hose to hold it in place Link to comment Share on other sites More sharing options...
