How To: The EASY Way to Change a CV
01silvapathy
  • 14 years later...
Old topic revive but dropping control arm method......does that avoid needing an alignment?  Just got an alignment then conveniently passenger side boot tears.  Trying to replace the axle without needing another alignment.   Thanks
As long as you do not mess with the strut bolts (22mm) your alignment should be fine.
