interchangeable parts?
Guest Colin
i just bought a 91 xe, i work at an auto wrecker, what pieces can i swap off of newer pathdiners? susp? interior? i really wanted to change the seats to leather. wich ones will work?
Since the body and interior specs are basically the same in 90-95 Pathfinders, most anything within these years are interchangable. Leather seats from within
these years should line right up to your existing seat mounts. The only difference has been interior styling between years and between models e.g. SE, XE, etc.
Keep in mind if you now have regular slider seats..you'd have to run wiring if the seats you get to replace the existing ones are powered, heated, etc..
