Key in ignition bell
JamesRich
Tired of hearing the bell when your key is in the ignition and your door is open but don't want to loose the reminder when you forget your lights on?
In the pictures I dropped the lower cover on the steering column and the little vent cover right below it to show the wires. All you need to remove is the lower cover with the little vent.
This is the two wires that sense the key in the ignition. the colors are red & white and Red & blue.
This is the connector that you need to unplug to stop the bell. After the connector the colors change to Solid pink and Brown & white.
Just unplug it and put your panel back. Now the bell won't sound when the key is in the ignition but it will remind you when you leave your headlights on.
