Question on 99 compass/temp
Guest GL36
I have a 99 Pathfinder SE and was wondering if anyone knows if it is possible to add the overhead console with the temp/compass. I took my console down to see if the wiring was there and it's not. It may take a different wiring harness which would be too much trouble.
There are separate wires to the Temp Sensor and compass that run up front(behind the grill) I couldn't see any "special" harness on mine. Looks to be pretty straight forward. If you can find one at a wreckers it would help you out a bit, and remember they are the same back to 96. :)
