tmoore4512 Posted August 2, 2010 Share Posted August 2, 2010 The JY donor is a 94 SE with ALL the options... Mine is a 95 SE, just missing the discs... While working at the zone, the computer does not show a different part number for the master cylinder between the 94-95. Maybe no change is required? Link to comment Share on other sites More sharing options...
wofat Posted August 7, 2010 Author Share Posted August 7, 2010 You might be able to just swap the axle shafts, you might have to change the brake lines (from the donor) as well. That's what the guy did to mine, if there's no issues with your diff it seems the easiest way to go. Link to comment Share on other sites More sharing options...
