Rear Diff.....
wofat
The JY donor is a 94 SE with ALL the options...
Mine is a 95 SE, just missing the discs...
While working at the zone, the computer does not show a different part number for the master cylinder between the 94-95.
Maybe no change is required?
You might be able to just swap the axle shafts, you might have to change the brake lines (from the donor) as well. That's what the guy did to mine, if there's no issues with your diff it seems the easiest way to go.
