vanuatoo Posted May 3, 2010 Share Posted May 3, 2010 (edited) It was raining for 2 days. Today when I was going downhill and did a hard right turn, one drop of water caught my eye. I looked up and there were two or three drops of water accumulated in the right map light. What do you recommend to isolate the issue? Edited May 3, 2010 by vanuatoo Link to comment Share on other sites More sharing options...
silverton Posted May 3, 2010 Share Posted May 3, 2010 Do you have have a sun or moonroof? the seal is probably leaking. Link to comment Share on other sites More sharing options...
vanuatoo Posted May 3, 2010 Author Share Posted May 3, 2010 Do you have have a sun or moonroof? the seal is probably leaking. I have a moonroof and it's probably leaking. I'm gonna look at it today and see if any drain hole is clogged. Link to comment Share on other sites More sharing options...
silverton Posted May 3, 2010 Share Posted May 3, 2010 I have a moonroof and it's probably leaking. I'm gonna look at it today and see if any drain hole is clogged. have someone with a hose run water over the top while look, it'll be much easier to find that way. I'm glad my wd21 is a hard top... Link to comment Share on other sites More sharing options...
