Pathfinder Windshield Washer Pump
raypeg
I hate acting like a retard, but I have to ask what I don't know....
Does my 2001 Pathfinder have just one windshield washer pump, which serves the front windshield, or does it have a second pump that serves the rear windshield?
Becasue the problem about my pathfinder, the front windshield washer decided stop working yesterday, the water won;t come out from the nozzle and the pipe under the hood ( rear one works fine), it works before. Looks like only one reason could be, the pump.
Any one can give me any tip how to check the pump working or not? I try to uninstall the fog light, and found out the pump is on the other side which I can not see, and it is impossible to reach windshield washer bottle from the hood.
Appreciate for the helps
if it is anything like a WD21 then yes 1 pump for the front, 1 for the back. You should be able to hear the pump if it is working with the truck off but the ignition on. I'm in the same situation back works great, front = nuthin
K, thanks for the help.
Take off the skid, it looks like this, yes, there are 2 pumps, the near one is for the front, the far one is for the rear, and I only can hear the motor running from the far one, seems like pump fail for the front.
So, I went to the local part store bought a pump which is kind of universal pump, which seems doesn't fit. Because on the OEM pump, there is 2 tubes on the motor, but the one I just bought, there is only one.
Seems like have to go to dealership to get a OEM pump on Monday
