Guest kwalker Posted October 3, 2004 Share Posted October 3, 2004 Have a 2001 PF that leaks water somewhere on drivers side. The water appears under the mat and occurs in a heavy rain. It must have a drain clogged somewhere......any ideas???? Link to comment Share on other sites More sharing options...
Guest hurasame Posted October 9, 2004 Share Posted October 9, 2004 I too have a 2001 Pathfinder. My guess, is that the Pathfinder has this drainage system like thing when you open the door. This has a tendency to get clogged with debris (leaves, dirt... etc). I simply just clean it out once in awhile. Maybe that could help? Link to comment Share on other sites More sharing options...
Guest trader Posted October 10, 2004 Share Posted October 10, 2004 Hi, I too have a 2001 Pathfinder and had the same problem with an older Maxima I sold. Yesterday, while installing a stereo I saw about a quart of water under the rug. Could you please explain how to clean out the debri. I tried to take the reservior apart under the glove box but it would not cooperate. I was thinking of shooting compresssed air up the drain tube but that will only work for a week of so if I can even find the tube. Thanks in advance. Link to comment Share on other sites More sharing options...
