4Wd Hi Wont Engage
IanH
Ok I searched, cant find anything....
2003 Part time 4WD SE pathy Auto.
the 4WD Hi wont engage, did work fine. ( ie push lever forward.)
4WD-Lo works fine ( Pull lever backwards.)
Any ideas what to check ?
Thanks
My R50 (and any others that I know of) requires you pull the lever back one spot for 4 hi. For 4 low, you have to pull back to 4 hi, then (with the transmission in neutral) pull back again to put the t-case into neutral, then push down, and pull back to 4 low.
If you don't have the owners manual, it should tell you how to use it on the back of your window visor.
