slobogus Posted January 23, 2010 Share Posted January 23, 2010 So I am doing my first 4wd disc rotor replacement on my 00 pathfinder.Looking at the manual I have it looks like I need to remove the hub cap snap ring drive flane lock washer bearing lock nut then the hub and bearing to actually remove the rotor.Is this correct or will the whole assembly come off with the rotor?Any help appreciated Link to comment Share on other sites More sharing options...
BowTied Posted January 23, 2010 Share Posted January 23, 2010 (edited) Welcome to NPORA!! The rotor is bolted to back side of the hub. So, the cap, clip and nut come off and then you can remove the washers and outer bearing IIRC. THe hub, rotor, and inner bearing come together. This is a good time to clean and grease your bearings too, I recommend getting new inner grease seals. I got seals but not from the dealer and I regret it as they were slightly different. Study the FSM, it is pretty decent. EDIT: I note that your profile says 1987, but you have posted in the 96-04 section.... I don't own an 87, so I can't say if I what I wrote is correct. Edited January 23, 2010 by BowTied Link to comment Share on other sites More sharing options...
slobogus Posted January 23, 2010 Author Share Posted January 23, 2010 Thanks bowtied did you need to use a special tool toget the bearing lock nut off the manual shows one.Mine is a 2000 my profile needs updating Link to comment Share on other sites More sharing options...
BowTied Posted January 23, 2010 Share Posted January 23, 2010 No, I did not use a special tool. It is not on very tight. A screwdriver or similar long item, maybe bent needle nose er something would work... at least for me. Link to comment Share on other sites More sharing options...
JUDGE Posted January 23, 2010 Share Posted January 23, 2010 I agree with BowTied, it's perfect time to re-grease your bearings. It's also a good time to check your CV boots for cracks and wear, getting the axles off isn't much more work from that point. Link to comment Share on other sites More sharing options...
