Lubricating Chassis
condor42
Hi everyone:
Got a question related to chassis lubrication for my Nissan Pathfinder 1995 XE V6 4x4.
Where are the points that need to be lubricated? Is only the bushings? the front drive shaft? And how can I be sure that the lubrication process was performed properly.
Thanks a lot for all!
You guys rock
Hm.. upper and lower balljoints, tie rod ends, idler arm. That's all I know of at the moment that has zerk fittings if they're already installed. Front driveshaft, repacking your wheel bearings, lubing all door hinges. Think that's it.
Hi guys:
First let me thank you each one of you for all the valuable information concerning lubrication it def. help me a lot.
I am learning a lot about my pathfinder thanks to all the posts, information as well as helpful and people with a lot of knowledge like you guys are.
I will post a couple more questions that I have (hopefully you guys don't mind) and can give me your valuable feedback
Thanks a lot and greeting from ultra-sunny Tucson-AZ
